SNTC portal does not show details of associated contracts
JoseHenriqueSTJ
I uploaded data to the SNTC portal, but it does not show the details of the associated contracts
My collector: CSP0009025784
Contract: 95670808
CCO: JoseHenriqueSTJ
Screen Below:
Suchita Shewale
Dear User,
We are looking at this issue, and will get back to you at the earliest.
Suchita
Portal continues without displaying the properties of the contracts.
Hello Jose,
I believe that the reason you are not seeing contract details is that while your devices are indeed covered, the contracts are owned by a third party, most likely your Cisco partner. The recommendation would be to contact your partner(s) so that they can make sure you are given visibility to your contracts.
Nathalie
