Hello
I dont think it can, that command is used with an acl is to define static pim so that IP will be the RP for specific MC groups
I think it can be negated by not having an interface PIM enabled and not statically applying the pim rp address, and If your using auto-rp then you can deifne a MC Scope or boundary.
Example:
R1<----5hops--->R6 ( R6 not to receive any Rp messages)
ip pim send-rp-discovery <interface) scope 4
or
R5
access-list 10 deny 224.0.1.40
access-list 10 permit any
int x/x
description link to R6
ip mulitcast boundary 10
res
Paul
Kind Regards
Paul
