Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928710members
1242482discussions
Community Activity
DNA Center and Meraki Dashboard
Hi,I'm trying to integrate the Meraki Dashboard in DNA Center (2.3.5), but I'm running into some issues.In the "Add Device" screen it asks for "API / Password" in the "HTTP(S)" section.If I input the API here, I can get the Organization details, but ...
mjrduarte by Level 1
  • 43 Views
  • 1 replies
Resolved! Recording Jabber - Overlapping Voices
Hello, I'm having this situation:In the call center we have PCs with softphones installed (Jabber) that replicate the traffic to a recorder in another site.Randomly, we are seeing high levels of Jitter in the flow that is replicated to the communicat...
Andriel by Level 1
  • 2909 Views
  • 11 replies
Catalyst3550:ACL設定のインバウンド/アウトバウンドの適用先について
L3スイッチのACL設定についての質問です。accecc-listコマンドで番号付きアクセスリストを作成し、(例:access-list 100 permit icmp 1.1.1.1 0.0.0.0 any echo)作成したVLAN(1.1.1.254/24)にアクセスリストを付けたいです。このとき、in/out を指定したいのですが、(ip access-group 100 in/out)このインバウンド/アウトバウンドというのは、何視点でのイン/アウトなのでしょうか?ポート→VLAN→L...
Yuukoide by Level 1
  • 21 Views
  • 1 replies
Connecting CX Cloud to Meraki Dashboard
Was looking to setup Meraki dashboard as a source for input to CX Cloud.  Is any one using this?  How easy was it to set up?  Any risks or important keys to success?
AP2702i degrading throughput
Hi community!I posted about some 2702i in autonomous mode, degrading throughput after some time - see post: Autonomous Mode Failing on Aironet 2702i-z-k9 - Cisco CommunityLast days I got a WLC 2504 and other 2702i access points  (in controlled - LWAP...
CSCwh18572 - Headless iPSK/mPSK
Why can't Cisco catch up and do this? It is such a simple concept. Aruba, Ruckus and even Ubiquiti can all do it. I don't mind running a Radius server but dot1x is not suitable for many environments. We have events where 5000 people turn up on first ...
vManage is not enough space for updating
Can't update vManage from 20.9.1 to 20.9.2.1[1-Mar-2023 6:03:11 MSK] Device: Failed to install: Signature verification Suceeded.\nSignature verification Suceeded.\nSignature verification Suceeded.\nerror-reason 'ERROR: Error: Disk space is not enough...
dijix1990 by VIP
  • 1262 Views
  • 11 replies
Trustsec Network Authorization not Working
Hi All,I am newly building trustsec in my environment,trying to add one of the switch under trustsec. Have configured Trustsec settings and COA on the ISE for the switch and added the appropriate aaa commands , radius servers and cts commands.But sti...
I am trying to upgrade ROMMON on 4331 from 15.4(r3)s5.
I am tying to upgrade the ROMMON from 15.4(r3)s5 to isr4200_4300_rommon_1612_2r_SPA.pkgthe output I get when I type in: upgrade rom-monitor filename bootflash:isr4200_4300_rommon_1612_2r_SPA.pkg allChassis model ISR4331/K9 has a single rom-monitor.Up...
sk002 by Level 1
  • 2694 Views
  • 16 replies
C9800 WNCd
i've seen this item "Site Tags AP to WNCd distribution" in best practice of C9800 Design and Deploymentmy quiestion is how can i configure multiple WNCd and where is the location of settings in webui?
Felix5 by Level 1
  • 211 Views
  • 9 replies
