01-13-2017 11:38 AM - edited 07-05-2021 06:21 AM
I remember there is a configuration on WLC for blocking the inter-user traffic (even users are on the same VLAN/SSID) but failed to find the feature in documentations. Anyone know the official name of the feature OR the configuration path to enable it?
Solved! Go to Solution.
01-13-2017 02:59 PM
There is a feature called "P2P blocking" which will prevent communication between users on the same WLAN.
There are some restrictions of this feature which is listed in above URL
Rasika
*** Pls rate all useful responses ***
01-13-2017 02:59 PM
Rasika
01-13-2017 03:42 PM
Perfect!! Thanks
