01-14-2017 08:14 PM - edited 03-08-2019 08:54 AM
I am getting above massage in the logs.
*Jan 14 21:51:58 CST: %BGP_SESSION-5-ADJCHANGE: neighbor 169.254.13.53 IPv4 Unicast vpn vrf driveprod topology base removed from session Peer closed the session
*Jan 14 21:52:02 CST: %BGP-5-NBR_RESET: Neighbor 169.254.13.13 active reset (Peer closed the session)
*Jan 14 21:52:02 CST: %BGP_SESSION-5-ADJCHANGE: neighbor 169.254.13.13 IPv4 Unicast vpn vrf driveprod topology base removed from session Peer closed the session
*Jan 14 21:52:08 CST: %BGP-5-ADJCHANGE: neighbor 169.254.13.53 vpn vrf driveprod Up
*Jan 14 21:52:12 CST: %BGP-5-ADJCHANGE: neighbor 169.254.13.13 vpn vrf driveprod Up
01-15-2017 01:23 PM
The messages indicate that you are running BGP, that you have two BGP neighbors, and that both BGP neighbors closed their BGP session and then opened new BGP sessions. Perhaps you should look on those neighbors to determine why they closed the BGP session.
It seems very odd to have BGP neighbors with IP addresses in the 169.254 network. Are you doing this intentionally?
Rick
01-16-2017 02:21 AM
The VRF aware BGP translate-update feature enables multicast forwarding on those customer-edge (CE) devices, whichhaveanolderversion of Ciscosoftware thatdoesnotsupport multicast BGP(mBGP) routing. The provider-edge (PE) devices establish a virtual routing and forwarding (VRF) session with the neighbor CE devices, and configure the translate-update feature under an IPv4/IPv6 VRF address family. The PE devices translate the updates from unicast to multicast on CE devices and put them as multicast updates in the Border Gateway Protocol (BGP) VRF routing table of the PE devices for processing.
refer - http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_bgp/configuration/xe-3s/irg-xe-3s-book/vrf-aware-bgp-translate-update.pdf
