What does ASA5506-SEC-BUN-K9 ASA 5506 with FirePOWER services and Sec Plus license include ?
ACHAL KRISHNA
Does the Sec Plus license include these three subscriptions ( IP, AMP, URL Filter) ?
Also can thee license L-ASA5506-SEC-PL ASA 5506 Security Plus - be applied to any of these ASA PART#s: ASA5506W-A-K9 or ASA5506-X or ASA5506H ?
Thanks!
Rahul Govindan
No, the security plus does not include the Firepower license. You need a separate license for the IPS, AMP and URL licenses. The part number for all 3 features should be: L-ASA5506-TAMC=.
The security plus license is only required on the 5506-X and the 5506H-X. The 5506H-X already has 30 VLANs and Active/Standby Failover features that the Security plus enables.
Hi, I would like to ask if ASA5506-SEC-BUN-K9 always includes the perpetual license for APEX VPN technology, or it can change from the sales region.
Which command ("show version" for example) is used to see if APEX Vpn is active?
What output should I expect?
I would also like to know if the EOL date of the ASA5506 appliances with ASA software is already known.
Thank you
========Firewall Output========
ciscoasa# sh ver
Cisco Adaptive Security Appliance Software Version 9.9(2)
Firepower Extensible Operating System Version 2.3(1.84)
Device Manager Version 7.10(1)
Compiled on Sun 25-Mar-18 17:29 PDT by builders
System image file is "disk0:/asa992-lfbff-k8.SPA"
Config file at boot was "startup-config"
ciscoasa up 6 days 2 hours
Hardware:   ASA5506, 4096 MB RAM, CPU Atom C2000 series 1250 MHz, 1 CPU (4 cores)
Internal ATA Compact Flash, 8000MB
BIOS Flash M25P64 @ 0xfed01000, 16384KB
Encryption hardware device : Cisco ASA Crypto on-board accelerator (revision 0x1)
                             Number of accelerators: 1
 1: Ext: GigabitEthernet1/1  : address is xxxx.xxxx.1064, irq 255
 2: Ext: GigabitEthernet1/2  : address is xxxx.xxxx.1065, irq 255
 3: Ext: GigabitEthernet1/3  : address is xxxx.xxxx.1066, irq 255
 4: Ext: GigabitEthernet1/4  : address is xxxx.xxxx.1067, irq 255
 5: Ext: GigabitEthernet1/5  : address is xxxx.xxxx.1068, irq 255
 6: Ext: GigabitEthernet1/6  : address is xxxx.xxxx.1069, irq 255
 7: Ext: GigabitEthernet1/7  : address is xxxx.xxxx.106a, irq 255
 8: Ext: GigabitEthernet1/8  : address is xxxx.xxxx.106b, irq 255
 9: Int: Internal-Data1/1    : address is xxxx.xxxx.1063, irq 255
10: Int: Internal-Data1/2    : address is 0000.0001.0002, irq 0
11: Int: Internal-Control1/1 : address is 0000.0001.0001, irq 0
12: Int: Internal-Data1/3    : address is 0000.0001.0003, irq 0
13: Ext: Management1/1       : address is xxxx.xxxx.1063, irq 0
14: Int: Internal-Data1/4    : address is 0000.0100.0001, irq 0
Licensed features for this platform:
Maximum Physical Interfaces       : Unlimited      perpetual
Maximum VLANs                     : 30             perpetual
Inside Hosts                      : Unlimited      perpetual
Failover                          : Active/Standby perpetual
Encryption-DES                    : Enabled        perpetual
Encryption-3DES-AES               : Enabled        perpetual
Carrier                           : Disabled       perpetual
AnyConnect Premium Peers          : 50             perpetual
AnyConnect Essentials             : 50             perpetual
Other VPN Peers                   : 50             perpetual
Total VPN Peers                   : 50             perpetual
AnyConnect for Mobile             : Enabled        perpetual
AnyConnect for Cisco VPN Phone    : Enabled        perpetual
Advanced Endpoint Assessment      : Enabled        perpetual
Shared License                    : Enabled        perpetual
Total TLS Proxy Sessions          : 100            perpetual
Botnet Traffic Filter             : Enabled        perpetual
Cluster                           : Disabled       perpetual
This platform has an ASA 5506 Security Plus license.
Serial Number: XXXXXXXXX
Running Permanent Activation Key: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Configuration register is 0x1
Image type                : Release
Key Version               : A
Configuration has not been modified since last system restart.
Please don't double post the same question.
Answered here:
https://community.cisco.com/t5/firewalls/cisco-asa-5506-x-vpn-license/m-p/3300237
