01-16-2017 01:41 AM - edited 03-19-2019 12:00 PM
Hi ,
need a solution document for Cisco meeting server with unified communication manager 11.1
Regars
manjunatha.K
Solved! Go to Solution.
01-17-2017 08:38 AM
I'll tell you how to get to it, and this works for pretty much any product
go to cisco.com
Hover over Support, click on the All Products that's on the left column (Product Support)
Then, you can either browse the decision tree, or click on Select a Product, if you do the latter, type meeting server and it will find the options, click on Meeting Server, and you'll get to the main page for ALL the CMS documentation.
The integration guide is in there.
01-16-2017 06:17 AM
Have you already reviewed the existing CMS documentation on cisco.com??
The integration procedure to use CMS as ad-hoc is covered there, and it's the same for any CUCM 10.5(2)+ release.
01-16-2017 09:24 PM
thanks for replay ,i could find any link for documenatation could please share link in cisco.com
01-17-2017 08:38 AM
go to cisco.com
