01-16-2017 07:19 AM - edited 03-01-2019 01:02 PM
Hi all
I have a UCS 8501, and two C220 M , the last 2 will be reinstalled with Linux, my question is ,there any way I can configure the 8501 to manage the C220?
Thanks.
Solved! Go to Solution.
01-16-2017 07:22 AM
Please review the following documentation: http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c-series_integration/ucsm2-2/b_C-Series-Integration_UCSM2-2/b_C-Series-Integration_UCSM2-2_chapter_0110.html
Hope this helps,
-AJ Felts
Cisco TAC
01-16-2017 07:22 AM
Hope this helps,
-AJ Felts
Cisco TAC
01-16-2017 10:47 AM
Hello Paul,
Thanks for you help, please let me ask you one thing so I can be sure I get this, I can connect my UCS 1110x directly to the Fabric, my UCS 2.2 will see this like a server or a disk ?
thanks !
01-16-2017 10:50 AM
Integration of 1110x is not supported. Only standalone C-Series servers are supported. The 1110x doesn't fall into the stand alone category.
When you integrate a normal C-Series server, it appears just like a blade, however it appears under "Rack-Mount" instead of "Chassis".
-AJ Felts
Cisco TAC
