01-17-2017 08:34 AM - edited 03-05-2019 07:51 AM
Hello -
We have two WAN 4600 series routers that have policies that limit the bandwidth to 10mb/s. I need the policies changed to match our new speed of 50. There's voice and data over the WAN with the below policies. Could someone please give me the command syntax for changing the policy-map to 50? Is it as simple as running:
Router(config)# policy-map METRO-10
Router(config-pmap)# bandwidth 52428800
Is it in bits/s or can I use mb?
class-map match-any VOICE
match ip dscp ef
match ip rtp 16384 16383
match ip precedence 5
class-map match-any VOICE-CTRL
match ip dscp af31
match ip dscp cs3
match access-group name QOS_callcontrol
policy-map METRO-PRIVATE
class VOICE
priority 512
class VOICE-CTRL
bandwidth 12
class class-default
fair-queue
policy-map METRO-10
class class-default
shape average 10000000
service-policy METRO-PRIVATE
interface GigabitEthernet0/0/0
description Connection to METRO-PRIVATE
bandwidth 10000
ip address x.x.x.x x.x.x.x
no ip redirects
speed 100
no negotiation auto
service-policy output METRO-10
bp
Solved! Go to Solution.
01-17-2017 09:41 AM
No, it's not that, but you're close.
What you need to do is:
policy-map METRO-10
class class-default
shape average 50000000
However, you might want to rename the policy to METRO-50 and you might want to change the bandwidth settings in the child policy, METRO-PRIVATE, to take advantage of the additional bandwidth.
You'll also probably should change the bandwidth setting, on the egress interface, to reflect the increased bandwidth too.
Lastly, I cannot say how a 4600 works, but on many other Cisco platforms, shapers, I believe, only account for L3 bandwidth, but providers often provide bandwidth as L2 bandwidth. If your shaper doesn't account for L2 overhead, I've found using a shaped value about 15% less usually accounts for average L2 overhead. (NB: insuring the shaper isn't allowing more bandwidth usage than available, is especially important when supporting VoIP. Also when when using QoS that supports VoIP, you might want to decrease the egress interface tx queue size.)
PS:
BTW, match IP prec 5 will also match IP DSCP EF.
01-17-2017 09:41 AM
policy-map METRO-10
class class-default
PS:
01-17-2017 02:51 PM
That worked - thanks for your help! I tried renaming the policy but it wouldn't recognize the rename command that I had found on a CCIE blog. Do I need to recreate the policy-map with a different name? Also, thanks for the QoS for VoIP info but I'm going to leave that to someone with more experience to tweak.
01-20-2017 02:57 PM
Yup.
Then you can replace the policy on the interface. After doing that you can remove the no longer needed policy.
