01-17-2017 09:25 AM - edited 03-08-2019 08:56 AM
01-17-2017 12:38 PM
Some people just see the price difference, regardless it's 5% or 20%, and that is the deciding factor.
The codes are the same. By the way, the "D" in the 3650 means the uplink ports are SFP/SFP+ while the 3850 is just SFP uplink only.
01-17-2017 01:39 PM
To add to Leo's comment, price is always a big factor. 10 to 15% may not be much when you are buying a few switches but if you are purchasing hundreds, it adds up.
01-18-2017 08:39 AM
Thank you very much everyone for your valuable feedback. So I feel that both choices are similar in feature except for some differences in price, backplane and uplink options. Both are safe choices and it all depends on budget and requirements.
07-09-2018 12:32 AM
The 3850 module comes with optional uplink modules which the customer can decide from 2x10G, 4x10G, 8x10G and 2x40G modules. That is why the -D is missing in the partcode.
01-17-2017 08:00 PM
You will also find that the uplinks are not included in the base price of a 3850 and you need to purchase the module that best suits. The options for the WS-C3850-48F-L model include 2xSFP+ or 4xSFP.
03-08-2018 03:51 AM
03-08-2018 04:14 AM
03-08-2018 04:26 AM
no i just need to know computability
04-18-2018 08:52 AM
I respectfully disagree. Platform is almost identical but price us not. On a small enterprise the 10%(and it is more) might seem irrelevant but on large customer environment scale that 10% will make a huge difference. Not only that. If unnecessary, why to pay even the 5% more? The cat3k are amazing platforms who represent already the past of Cisco. Cat9k is kicking in and Cisco has even more surprises for us to come. Hardware refresh is a periodic task which should never be missed and hence never oversized.
Hope this helps
07-09-2018 05:39 AM
Just dont go for the 3850.
IMO its one big terrible bug with 52 ports
