Auto Disconnecting PSTN Calls after 30 Minutes
aniket0422
Hi All,
Can we configure CUCM to automatically disconnect PSTN calls after 30 minutes of time.
If Yes, Please guide me through the process for same.
Aniket P. Raut
Jaime Valencia
No, the only setting you get out of the box, controls ALL calls, every single call, would disconnect at 30 minutes if you change the parameter.
The only way to do that, involves custom development via external call control profiles or TCL scripting on the outbound GW.
java
if this helps, please rate
