ā01-17-2017 12:57 PM - edited ā03-08-2019 08:56 AM
hi folks .
right now i have ASR 1002
IT HAS 2 modules one with 4 ports
and one with 8 ports
but i need to have like 3-4 ports of 10G
i just need advices which parts are close to my chasis and will be supporting my routing to handle 10G for each port interface .
here is my config :
Gateway-ASR1002>sh ve
Gateway-ASR1002>sh version
Cisco IOS XE Software, Version 03.13.00.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.4(3)S, RELEASE SOFTWARE (fc11)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Mon 28-Jul-14 04:11 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Gateway-ASR1002 uptime is 51 weeks, 2 days, 2 hours, 6 minutes
Uptime for this control processor is 51 weeks, 2 days, 2 hours, 10 minutes
System returned to ROM by reload at 09:36:31 Riyadh Sun Jan 24 2016
System restarted at 18:49:38 UTC Sun Jan 24 2016
System image file is "bootflash:asr1000rp1-adventerprisek9.03.13.00.S.154-3.S-ext.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1002 (2RU) processor (revision 2RU) with 1650501K/6147K bytes of memory.
Processor board ID FOX1807GBZW
12 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7757823K bytes of eUSB flash at bootflash:.
Gateway-ASR1002>
Gateway-ASR1002>
Gateway-ASR1002>
Gateway-ASR1002>
Gateway-ASR1002>
Gateway-ASR1002>sh inve
Gateway-ASR1002>sh inventory
NAME: "Chassis", DESCR: "Cisco ASR1002 Chassis"
PID: ASR1002 , VID: V06, SN: FOX1807GBZW
NAME: "module F0", DESCR: "Cisco ASR1000 Embedded Services Processor, 5Gbps"
PID: ASR1000-ESP5 , VID: V04, SN: JAE18110AU1
NAME: "Power Supply Module 0", DESCR: "Cisco ASR1002 AC Power Supply"
PID: ASR1002-PWR-AC , VID: V03, SN: ART1804U03P
NAME: "Power Supply Module 1", DESCR: "Cisco ASR1002 AC Power Supply"
PID: ASR1002-PWR-AC , VID: V03, SN: ART1804U05H
NAME: "module 0", DESCR: "Cisco ASR1002 SPA Interface Processor 10"
PID: ASR1002-SIP10 , VID: , SN:
NAME: "SPA subslot 0/1", DESCR: "8-port Gigabit Ethernet Shared Port Adapter"
PID: SPA-8X1GE-V2 , VID: V02, SN: SAL1530KVLF
NAME: "subslot 0/1 transceiver 1", DESCR: "GE SX"
PID: GLC-SX-MMD , VID: A , SN: FNS163810QC
NAME: "subslot 0/1 transceiver 2", DESCR: "GE T"
PID: SP7041-E , VID: F , SN: MTC152800A7
NAME: "subslot 0/1 transceiver 3", DESCR: "GE T"
PID: SP7041-E , VID: F , SN: MTC1528007H
NAME: "subslot 0/1 transceiver 7", DESCR: "GE T"
PID: SP7041_Rev_F , VID: F , SN: 00000MTC16370AA4
NAME: "SPA subslot 0/0", DESCR: "4-port Gigabit Ethernet Shared Port Adapter"
PID: 4XGE-BUILT-IN , VID: , SN:
NAME: "subslot 0/0 transceiver 0", DESCR: "GE LX"
PID: FTLF1318P2BCL-CS , VID: A000, SN: FNS1352S020
NAME: "subslot 0/0 transceiver 1", DESCR: "GE T"
PID: SFP-GE-T , VID: , SN: MTC1231005A
NAME: "subslot 0/0 transceiver 2", DESCR: "GE T"
PID: SFP-GE-T , VID: , SN: MTC1229019M
NAME: "subslot 0/0 transceiver 3", DESCR: "GE LX"
PID: FTRJ-1319-7D-CSC , VID: , SN: H824106
NAME: "module R0", DESCR: "Cisco ASR1002 Route Processor 1"
PID: ASR1002-RP1 , VID: V06, SN: JAE18110F7G
Gateway-ASR1002>
ā01-17-2017 01:58 PM
The SPA module for the ASR-1002 has only one 10gig port. So, if you replace all your existing 1Gig SPA modules, you can have a max of 3 10Gig ports (one per card). Here is the part #
Cisco 1-Port 10 Gigabit Ethernet Shared Port Adapter, Version 2
ā01-17-2017 08:15 PM
btw, ESP5 is not enough for high traffic :-)
ā01-19-2017 04:38 AM
thanks all .
one more Q
will any of the items below are supported to my ASR with hardware info above
XFP-10G-MM-SR= |
10GBASE-SR XFP Module |
1 |
$500+VAT |
XFP-10GLR-OC192SR= |
Multirate XFP module for 10GBASE-LR and OC192 SR-1 |
1 |
$1000+VAT |
SPA-1X10GE-L-V2= |
Cisco 1-Port 10GE LAN-PHY Shared Port Adapter |
1 |
$2,500+VAT |
also what to choose , single mode or multi mode ?
ā01-19-2017 06:30 AM
one of them is the part number I provided you in the first post.
XFP-10G-MM-SR= is the optic that goes with the module.
As for single more or multi-mode, it all depends on your distance. If the distance is less than 500 meters use multi-mode. if it is more than use single mode.
ā01-17-2017 11:17 PM
is there any module that has many 10g interfaces ?
ā01-18-2017 01:48 AM
No, not for ASR1002, only for 1004 and above:
http://www.cisco.com/c/en/us/products/collateral/application-networking-services/wide-area-application-services-waas-software/data-sheet-c78-729778.html
