01-19-2017 06:59 AM
Would like to know if I can suppress the auto update feature on Proximity installer?
In log file i can still see that application verify's auto update each time when started :
Info: Auto update: checking for new version: https://proximity.cisco.com/windows/version.txt
Is there is any way how can we avoid this ?
It is critical if we want to install package on enterprise.
Is there is any resource with old versions (https://proximity.cisco.com/changelog.html) installers available ?
Thanks.
Solved! Go to Solution.
01-20-2017 04:02 AM
I understand that would be useful. I'll attach version 2.0.2 here!
The user is presented with a balloon, and needs to right-click the tray icon and select “Upgrade now” before the UAC pop-up is shown.
01-23-2018 12:22 AM
With respect to the disabling of auto upgrade, please also check https://supportforums.cisco.com/t5/mobile-applications-documents/windows-mass-deployment-guide-new-as-of-version-2-0-8/ta-p/3314009
01-20-2017 03:13 AM
The old versions are not available, as we do not support them. Running older versions would incur bugs, and would not work with new or future versions of CE software.
Other than that, there are two options for deploying Proximity: per-user installations and per-system installations. In per-system installations, Proximity will always prompt the user before proceeding with installation. That is the closest we have to matching your feature request.
Implementing a feature for disabling auto update is not currently planned.
01-20-2017 03:41 AM
Is see reason why old versions are not available, but can i download previous versions of Proximity for deployment test purpose not for application functionality ?
I would like to see how user is prompted for new version, (is there is informative message or UAC to proceed upgrade with admin rights) ?
01-20-2017 04:02 AM
01-20-2017 05:38 AM
Thanks for quick answer.
01-23-2018 12:22 AM
