Intravlan netflow on 3850
We've set up netflow on our core switch and it works, we are capturing all inter-vlan traffic.
We are also trying to get traffic that flows inside a vlan on an edge switch (that traffic does not reach the core switch).
We are running 3850 with  03.07.04E
We cannot get the flow record applied to the vlan it errors out.
Here is our config:
flow exporter AWSSplunk
 description test
 destination x.x.13.245
 transport udp 2055
 template data timeout 60
 option interface-table timeout 60
 option application-table timeout 60
flow monitor MONITOR1
 exporter AWSSplunk
 cache timeout inactive 30
 cache timeout active 60
flow record RECORD1
 match datalink mac source address input
 match datalink mac source address output
 match datalink mac destination address input
 match ipv4 source address
 match ipv4 destination address
 match flow direction
When applying to vlan 10:
sw(config)#vlan configuration 10
sw(config-vlan-config)#ip flow monitor MONITOR1 input
% Flow Monitor: Flow Monitor 'MONITOR1' cannot be added as this monitor does not have a valid Flow Record.
What are we missing?
Reza Sharifi
Your flow record is named "'RECORD1" can you change it to "MONITOR1" and test again?
Thank you!
I forgot to add RECORD1 to MONITOR1
It works now
