01-19-2017 12:10 PM - edited 03-17-2019 09:15 AM
I have strange issue for cisco 8851 and 8861 when I use them connect to the switch port of phone the laptop internet speed is different
And when I connect the 7941 or 7961 phone it is quite good.Phones are in same vlan and auto qos is enabled
Switch is 3650 for the CUCM and 3550 switch is connected to the phone everything is wired
Firmware version on 8851 is 11-5-1-18
DJ
01-19-2017 03:42 PM
Have you looked into the software versions on the switch ?
What about opening a TAC case?
01-23-2017 10:19 AM
yes the software version is good latest one rebooted the switch but same issue
Checked the config setting on the phone all good.No Idea why that happens
DJ
01-23-2017 11:53 AM
Make sure the phone has negotiated 1000Mb/Full Duplex with both PC and Access Switch.
Check the phone's web page under Network and Access. While you are there, look for Collisions and some of the other packet errors. Next, check the Switchport and PC to make sure they agree with the phone on Speed and Duplex.
A couple of years ago, I had some problems with 8851s not negotiating 1000Mb with the switch. Upgrading switch firmware fixed the problem. I am also running 11-5-1-18 on my phones. I have a few locations where the cable plant won't allow me to run 1000Mb. In those cases, I manually set the phone to run 100/Full on both Network and Access ports.
Randall
