I have a laptop with Windows 7 64bit installed, and the 4.2.04018 version of AnyConnect to connect to my employer's VPN.
When at home, I connect via buffalotech dot com site /products/airstation-highpower-n600-gigabit-dual-band-open-source-dd-wrt-wireless-rou
Every so often the VPN stops. The WiFi connection itself is stable.
Most of the times, the lock icon from the AnyConnect icon in the tray doesn't even disappear. However, I can tell because my SSH connection breaks, then a few seconds later the green box "VPN Reconnecting" shows up on the bottom right of my screen.
Any ideas how I can even start troubleshooting? Obviously I don't have access to the server or anything, but speaking with my employer's IT support shows they don't see any wierd behavior on their end. Also, when I am on a wired connection, when I am connected to my Unifi access point or when I am connected to my library's WiFi for example, the VPN connectivity is relatively stable, making me think there's something going on with my dd-wrt and my laptop.
Any suggestions on how I can start debugging and what the problem might be?
