tacacs+ and TrustSec
Is it possible to use tacacs+ and TrustSec on the same device?
I think that configurations of tacacs + can not set several TrustSec configurations.
For example, pac key etc.
Ravi Singh
Level 7
Level 7
Check the following link
https://communities.cisco.com/docs/DOC-63930
Thanks for your replay.
I understood a no problem thing about ISE.
However, it's about the possibility about catalyst switches, routers and firewalls that I want to know primarily.
