How to fix dhcp failed issue caused by " deny-all"
o.djere01
Interface   Filter-type    Filter-mode    IP-address     Mac-address     Vlan
Gi1/14          ip                 active            deny-all                                  215
Think you
lpassmore
If you still need help with this, can you post the device type and the command that gives you this output.  Also, if you post a sanitised version of your config that will help us respond.
Otherwise, if you have found and answer, post it so others can learn from it.
