01-22-2017 09:37 PM - edited 03-08-2019 09:01 AM
Hi All,
Hoping you can help me with this.
I have a site that is using RIPv2 to advertise its routes using the following settings on a WS-C3650-24TS running 03.03.04SE :-
router rip
version 2
redistribute connected
passive-interface default
network 10.0.0.0
neighbor 10.204.0.13
distribute-list 14 out Vlan100
no auto-summary
access-list 14 remark PREVENT ANNOUNCING EXISTING SUBNET
access-list 14 permit 10.204.0.24 0.0.0.7
access-list 14 permit 10.197.0.0 0.0.15.255
access-list 14 permit 10.20.0.0 0.0.255.255
access-list 14 permit 10.21.0.0 0.0.255.255
access-list 14 deny any
The Configuration on the Interfaces is as follows.
interface Vlan99
ip address 10.197.0.1 255.255.255.0
ip helper-address 10.20.4.1
no ip split-horizon
ip summary-address rip 10.197.0.0 255.255.240.0
interface Vlan100
ip address 10.204.0.9 255.255.255.248
interface Vlan110
ip address 10.197.2.1 255.255.255.128
no ip split-horizon
interface Vlan115
ip address 10.197.2.129 255.255.255.128
no ip split-horizon
interface Vlan120
ip address 10.197.3.1 255.255.255.0
no ip split-horizon
interface Vlan121
ip address 10.197.4.1 255.255.255.0
no ip split-horizon
interface Vlan200
ip address 10.197.5.1 255.255.255.0
no ip split-horizon
interface Vlan400
ip address 10.197.7.1 255.255.255.0
no ip split-horizon
interface Vlan410
ip address 10.197.8.1 255.255.255.192
no ip split-horizon
interface Vlan411
ip address 10.197.8.65 255.255.255.192
no ip split-horizon
interface Vlan500
ip address 10.197.9.1 255.255.255.192
no ip split-horizon
interface Vlan501
ip address 10.197.9.65 255.255.255.192
no ip split-horizon
interface Vlan510
ip address 10.197.10.1 255.255.255.0
no ip split-horizon
interface Vlan520
ip address 10.197.11.1 255.255.255.128
no ip split-horizon
interface Vlan521
ip address 10.197.11.129 255.255.255.128
no ip split-horizon
interface Vlan600
ip address 10.197.12.1 255.255.255.128
no ip split-horizon
interface Vlan601
ip address 10.197.12.129 255.255.255.128
no ip split-horizon
interface Vlan610
ip address 10.197.13.1 255.255.255.0
no ip split-horizon
As you can see all the subnets that are advertised are withing the 10.197.0.0 255.255.240.0 Mask
The Output of show ip rip database shows
10.197.0.0/20 int-summary
10.197.0.0/24 directly connected, Vlan99
10.197.2.0/25 directly connected, Vlan110
10.197.2.128/25 directly connected, Vlan115
10.197.3.0/24 directly connected, Vlan120
10.197.4.0/24 directly connected, Vlan121
10.197.5.0/24 directly connected, Vlan200
10.197.6.0/24 directly connected, Vlan20
10.197.7.0/24 directly connected, Vlan400
10.197.8.0/26 directly connected, Vlan410
10.197.8.64/26 directly connected, Vlan411
10.197.9.0/26 directly connected, Vlan500
10.197.9.64/26 directly connected, Vlan501
10.197.10.0/24 directly connected, Vlan510
10.197.11.0/25 directly connected, Vlan520
10.197.11.128/25 directly connected, Vlan521
10.197.12.0/25 directly connected, Vlan600
10.197.12.128/25 directly connected, Vlan601
10.197.13.0/24 directly connected, Vlan610
And the output of show ip protocols is :-
*** IP Routing is NSF aware ***
Routing Protocol is "rip"
Outgoing update filter list for all interfaces is not set
Vlan100 filtered by 14 (per-user), default is not set
Incoming update filter list for all interfaces is not set
Sending updates every 30 seconds, next due in 28 seconds
Invalid after 180 seconds, hold down 180, flushed after 240
Redistributing: connected, rip
Neighbor(s):
10.204.0.13
Default version control: send version 2, receive version 2
Automatic network summarization is not in effect
Address Summarization:
10.197.0.0/20 for Vlan110
10.197.0.0/20 for Vlan99
10.197.0.0/20 for Vlan115
10.197.0.0/20 for Vlan120
10.197.0.0/20 for Vlan121
10.197.0.0/20 for Vlan200
10.197.0.0/20 for Vlan400
10.197.0.0/20 for Vlan410
10.197.0.0/20 for Vlan411
10.197.0.0/20 for Vlan500
10.197.0.0/20 for Vlan501
10.197.0.0/20 for Vlan510
10.197.0.0/20 for Vlan520
10.197.0.0/20 for Vlan521
10.197.0.0/20 for Vlan600
10.197.0.0/20 for Vlan601
10.197.0.0/20 for Vlan610
Maximum path: 4
Routing for Networks:
10.0.0.0
Passive Interface(s):
Vlan1
Vlan20
Vlan99
Vlan101
Vlan110
Vlan115
Vlan120
Vlan121
Vlan200
Vlan300
Vlan400
Vlan410
Vlan411
Vlan500
Vlan501
Vlan510
Vlan520
Vlan521
Vlan600
Vlan601
Vlan610
Routing Information Sources:
Gateway Distance Last Update
10.204.0.13 120 00:00:07
Distance: (default is 120)
So as far as I can see it should only be announcing 10.197.0.0/20 to the Router.
But, looking at the router connected to this switch, I see the Following :-
#show ip route | inc 10.197
R 10.197.0.0/24 [120/2] via 10.204.0.77, 00:00:00, Vlan101
R 10.197.2.0/25 [120/2] via 10.204.0.77, 00:00:20, Vlan101
R 10.197.2.128/25 [120/2] via 10.204.0.77, 00:00:20, Vlan101
R 10.197.3.0/24 [120/2] via 10.204.0.77, 00:00:25, Vlan101
R 10.197.4.0/24 [120/2] via 10.204.0.77, 00:00:16, Vlan101
R 10.197.5.0/24 [120/2] via 10.204.0.77, 00:00:06, Vlan101
R 10.197.6.0/24 [120/2] via 10.204.0.77, 00:00:20, Vlan101
R 10.197.7.0/24 [120/2] via 10.204.0.77, 00:00:08, Vlan101
R 10.197.8.0/26 [120/2] via 10.204.0.77, 00:00:24, Vlan101
R 10.197.8.64/26 [120/2] via 10.204.0.77, 00:00:24, Vlan101
R 10.197.9.0/26 [120/2] via 10.204.0.77, 00:00:00, Vlan101
R 10.197.9.64/26 [120/2] via 10.204.0.77, 00:00:00, Vlan101
R 10.197.12.128/25 [120/2] via 10.204.0.77, 00:00:04, Vlan101
R 10.197.11.128/25 [120/2] via 10.204.0.77, 00:00:04, Vlan101
R 10.197.13.0/24 [120/2] via 10.204.0.77, 00:00:17, Vlan101
R 10.197.12.0/25 [120/2] via 10.204.0.77, 00:00:17, Vlan101
R 10.197.11.0/25 [120/2] via 10.204.0.77, 00:00:17, Vlan101
R 10.197.10.0/24 [120/2] via 10.204.0.77, 00:00:17, Vlan101
I'm guessing I've done something really stupid, Anyone got any idea's as to what I've done??
Matthew
01-24-2017 05:36 AM
Could you tell us about your neighbour peer? It seems that the neighbouring is done through vlan 101 (what the output shows) however on your rip configuration you just allowed neighbour 10.204.0.13 that corresponds to vlan 100 (on your config output).
Which one is correct?
Anyway, on this vlan 100 you didn't set the ip summary rip command.
PS: Please don't forget to rate and mark as correct answer if this answered your question
