01-22-2017 09:51 PM - edited 03-13-2019 09:44 PM
When a RJ11 headset was plugged into the headset port, it doesn't work. The headset can work when plugged into the handset port. What are the recommended RJ or headsets for 7942?
01-23-2017 05:05 AM
Hi Zann,
The headset port on the back of the 7942 is RJ11, I have encountered this problem before due to different headset cables not being cross compatible with different phone vendors. Check compatibility with your headset vendor.
If you have a plantronics headset you need the curly cord with the opaque (grey) glass end. Alternatley you can purchase a headset amplifier.
Check out the link below
http://www.plantronics.com/uk/compatibility-guide/
Simon
01-23-2017 06:12 AM
Some other compatibility links that might be useful:
Jabra
http://www.jabra.com/headsets-and-speakerphones/compatibilityguide
Plantronics
http://www.plantronics.com/us/compatibility-guide/#/search/
Sennheiser
http://en-de.sennheiser.com/telephone-headset-compatibility
Leszek
