voicemail
mike.absher
Is there a way to see a forgotten pin number for voicemail or to reset without the number?
Anoop Krishnan
Do you have the access to your Unity Connection Server and the credentials to login, if so, you could reset the PIN.
You could also reset if you have PCA (Personal Communications Assistant) enabled.
Anoop
