01-23-2017 11:02 AM - edited 03-12-2019 01:49 AM
We currently have a pair of ASA5525-X's as our external facing FW's and are looking into now replacing our internal
FW's. I am currently looking at the 5515-X, 5516-X & 5525-X, although I think the 5525-X maybe over kill for us and also costly.
We are looking at getting as close as possible to a Gig throughput and will not be running any sort of IPS, Firepower or VPN services on these FW's. We need as close as possible to a gig throughput so as not to cause a bottle neck with the ASA's. (5516-X should be ok with 900Mbs of Multiprotocol throughput)
From a quick look at the specifications of the ASA's the 5516-X looks to be on par if not better than the 5515-X apart from no expansion slot.
I would like to keep consistency to software downloads as much as possible so that if a software patch is released we only need to apply the one
patch to all FW's. From what I have read the ASA5506-X, 5508-X & 5516-X are built on the same security platform as the 5515-X & 5525-X series, however I see that when you come to download software for the 5506-X,5508-X & 5516-X it's a different download to the 5515-X & 5525-X series, is this just down to the physical hardware of the ASA's as the software versions seems to be the same?
If anyone has any thoughts or experiences on why not to use the ASA5516-X over the 5515-X I would be grateful to hear of your experiences.
Shaun
01-23-2017 01:54 PM
The image, although named differently, has the same functionality in an ASA5515 vs ASA5516. The difference is that the newer ASA models (5508,16 etc) support digitally signed images to enhance security. More on this can be read here:
http://www.cisco.com/c/en/us/about/security-center/intelligence/asa-integrity-assurance.html
Now as far as using the ASA5515 vs 5516, I have used both in customer environments and cannot tell one from another, except during the initial boot or upgrade phase. The ASA5516 has better performance compared to 5515 owing to the newer hw. But this helps as it sits right in between the ASA5515 and 5525 models in terms of throughput. If you can get around the difference in image names (versions remain the same), the 5516 is a good way to go.
01-27-2017 10:38 AM
Please see the below url for compatibility matrix for more detailed info.
http://www.cisco.com/c/en/us/td/docs/security/asa/compatibility/asamatrx.html
Hope to help.
