KVM Console showing No Signal
Hi Guys,
We have a ucs-c250-m1 server. When i access Esxi with KVM Console, getting error like "No Signal".
Please find the Picture which i attached along with this mail
Thanks and Regards,
Nisar
7 Replies 7
Ammar Saood
kindly check if the ports required for KVM are opened between your machine and server.
turn off your windows firewall or any
try testing again
AMMAR
Hi Ammar,
Thank you.
I have turned off my PC Firewall. but still no Luck.
then i have directly connected a Monitor to UCS Server. Monitor showing VGA No Signal.
Should i install new EsXi on Server?
Kindly Suggest
Nisar KP
Hi Guys,
Any Solution for this issue?
subhanzaheer901
Urgent : I have UCS 240 m3 server . System status light yellow. i insert ram in A1 B1 for cpu 1 and for cpu 2 E1 F1. 16gb * 4 .. i'm unable to get display. how to get display of ucs server .
Press Macros+Static Macros+F1
This worked for me.  Thanks!
Macros+Static and Macros+F1 is the only solution to this problem.
TechyPerson
