01-24-2017 11:06 AM - edited 03-05-2019 07:54 AM
Hello guys,
Have a little problem with my cisco router 2900..while doing certain configurations, i did a "format flash" by so doing all the content of the flash was gone..together with the IOS. I've tried to reload a new IOS using a TFTP and the Xmodem method but it is not going through. Don't really know what to do....
01-24-2017 12:51 PM
This method of loading an IOS into a router or switch using XModem is so old school.
The most effective and fastest way to do this are the following options:
1. The IOS is always stored in a REMOVABLE compact flash. Eject the flash and load the IOS using a multi-card reader; or
2. Every router and switch now sports one (or two) USB ports. With a correct (and supported) USB flash drive, it is possible to boot an IOS from a USB flash drive.
01-24-2017 11:24 PM
Thanks for the reply Leo Laohoo,
I tried this mehtod but when i do the "dir usbflash0" i have this mistake
program load complete, entry point: 0x80903000, size: 0x4c4a0
fnuhcd5200OpenPipe ERROR opening PIpe CVMX
*** TLB (Load/Fetch) Exception ***
Access address = 0x26
PC = 0x8090f0c0, SP = 0x80902dc0, RA = 0x8090f560
Cause Reg = 0x80000008, Status Reg = 0x504080e3
01-24-2017 11:43 PM
The USB flash drive is not supported by the router.
01-25-2017 01:08 AM
okay, and do you certain criteria of the appropriate flash drive?
01-25-2017 05:25 PM
No.
Not all USB brand (and sizes) are supported by Cisco appliances. This is because some manufacturers don't follow the standards to what Cisco require.
So test a few brands and sizes. You'll know if the particular brand and size works when the logs will reflect this.
01-25-2017 08:11 PM
To Leo's point about drives, you may want to check your box if you still have.it. A lot of the cisco 2900's and 3900's come with 1 gb flash drives. It's likely compatible with your router.
01-26-2017 12:05 AM
it's because Floria is an OG
**Sorry can't help it...hahahaha**
