01-24-2017 06:44 PM - edited 03-17-2019 09:18 AM
I have a VG204 that will not dial out on 2 of the ports, it will receive faxes but when the user attempts to dial out to fax, they are receiving a fast busy. The ports are configured identical to the other 2 on the VG and will receive and send. I reset/restarted the port on the gateway and it does not help, I also ran DNA and I can see the number hit the gateway. Any help would be great!
01-24-2017 09:24 PM
I understand it's an Inter-digit Timeout issue,
Under the voice-port please issue:
VG204-2(config-voiceport)#timeouts interdigit 12
VG204-2(config-voiceport)#shut
VG204-2(config-voiceport)#no shut
Anoop
01-25-2017 04:57 AM
Anoop,
Thank you for the response, I will test this out today and will post the results.
Thanks again!
01-25-2017 05:53 AM
What is your topology? Is there CUCM here or CME or something else?
Are you dialing internal or external extension?
If using CUCM what protocol controls the GW/ports? SIP, H323, SCCP, MGCP?
