RSP880 on ASR9010 V1 Chassis
Hi Experts,
We have a customer with a lot of ASR9010 with the V1 chassis, and they want to migrate the RSP-4G to the RSP-880, but I have a doubt about if we also must change the PEMv1 to the PEMv2 or PEMv3.
I tried to search for some information about the power supply that are supported by the RSP880 and the V1 is not mentioned, so I don't know if they are supported or not.
I'm noticed that the Tomahawk LC's only support the v2 and v3 PEMs, and as the RSP880 is launched to support the TH LC, I will assume that the RSP880 also needs the v2 and v3 PEMs, but I need a confirmation.
Thanks a Lot
Emiliano
smailmilak
Level 4
Level 4
I am pretty sure that V1 is not supported anymore. My recommendation is to go with v3 and you will also be ready for future hardware that will be released.
Check out this screenshot from Cisco Live BRKARC-2003.
