Cisco 2960 switch port configuration
sultan.ahmed21
I am trying to take a switch port from voice vlan and put into only access vlan.
SWtich type:
switch 1 provision ws-c2960s-48lpd-l
switch 2 provision ws-c2960s-48lpd-l
Current configuration of a port:
interface GigabitEthernet1/0/11
switchport access vlan 301
switchport mode access
switchport voice vlan 410
spanning-tree portfast
I want to take this port out of voice vlan 410.
I use the command
#no switchport voice vlan 410
It immediately takes the switchport out of vlan 301 as well and put the port in valn1. There are other switches in the network.
If I use the command:
#switchport mode access
#switchport access vlan 301.
It immediately put the port into vlan 410 as well.
It is seems that two vlans are bound.
Can  not figure out how to troubleshoot.
Any help will be highly appreciated.
Leonardo Gama
Hi Sultan,
Try to default the interface before applying the final configuration:
conf t
default interface GigabitEthernet1/0/11
end
Cheers.
Leonardo Gama
Hi Sultan,
conf t
end
Cheers.
Hi Leonardo,
Your solution worked perfectly. Thank you very much.
Sultan
That is not a normal behavior to set up the config automatically, try to default the interface.
conf t
default interface G1/0/11 once implemented type this command:
conf t
interface G1/0/11
switchport host
and check again with your data vlan. Are you using Macros?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
