TMS Automatic Software Upgrade
Have a customer with a new TMS 15.3 installation
He is getting an error when the system is trying to connect and get software upgrades.
I think this is a credential issue because I can reach cisco.com from the server.
I am not finding where within the configuration I add a CCO credentials for the system to connect.
Where did I miss this?
May or may not be related, but if the endpoints are running TC6.1 or later (including endpoints running CE software), TMS will not automatically download software for them, see the New Software Download Procedure for TelePresence Endpoints running TC Software.
Regarding the "MCS8010", I don't recognize that name, do you by chance mean "MSE 8000" or one of it's various blades maybe?  In the case infrastructure systems, TMS doesn't automatically download software for them, as those devices are upgraded manually by the user.
10 Replies 10
Patrick Sparkman
The automatic software update service that TMS uses doesn't require authentication.
What error are you seeing in TMS in regards to the software update service?
What endpoints are you trying to upgrade, and what is their current software versions?
Here is the error
The background event could not complete successfully due to an error.
Description: Check for Software Updates
Start Time: 1/31/2017 12:00 AM
Completed Time: 1/31/2017 12:01 AM
Failure Reason: Update check failed. Please see system logs for details. Note that TMS must have internet access to contact the software update service.
Could be a number of things, have you checked the TMS diagnostic logs to see what the issue might be?
Pat
will check when i get to a network connection
thanks
Pat,
Here is the log file I think you are looking for.
Appreciate your feedback.
If there is a different log, let me know.
Looks like something is stopping your TMS from making a connection, someone a few years back had a similar issue, though they didn't post what the issue was.  If you take a look at their thread, tms-automatic-software-update-fails, going by what Mangus mentions, try taking a Wireshark trace from your TMS server.
Also, what endpoints are you trying to upgrade?
Pat, I have SX10''s and SX20's plus an MCS8010.
Also an EX60 and a C40
Pat,
This is probably it.  Will tell the customer to disable this and not worry again.
Thanks for finding this jewel
TMS will often report this "Update check failed" message for devices that are Virtual Machines, as part of the upgrade check process queries the MAC address of the device.  With most VMs, the back end Cisco systems do not contain that information, so the update check will fail.
You can fix this by contacting Cisco Global Licensing Operations and they can log a job with Cisco IT to have the back end databases updated with your corrected MAC addresses so the update check no longer fails.
We've had to do this with a number of our Virtualised devices (ie VCS).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
