02-01-2017 10:26 AM
Hello All,
Switch: WS-C4507R-E
Supervisor Slots:
NAME: "Supervisor(slot 3)", DESCR: "Supervisor 6L-E 10GE (X2), 1000BaseX (SFP) with 2 10GE X2 ports" PID: WS-X45-SUP6L-E , VID: V04 , SN: ********** NAME: "Supervisor(slot 4)", DESCR: "Supervisor 6L-E 10GE (X2), 1000BaseX (SFP) with 2 10GE X2 ports" PID: WS-X45-SUP6L-E , VID: V04 , SN: **********
The Supervisor slots are the one's containing the Fiber/SFP ports. At the moment only the Supervisor in slot 3 is "Active", and the one in Slot 4 is the "Standby". I haven't worked much with the SFP ports so I was hoping someone could help me identify if there are any open ports?
Here is a screenshot from the Cisco Network Assistant app showing the Supervisor slots from the Front Panel view of the 4507R.
Here is the show int status output for slots 3 and 4.
#show int status | inc Gi[3-4] Gi3/3 connected trunk full 1000 1000BaseSX Gi3/4 notconnect 1 full 1000 No Gbic Gi3/5 inactive 1 full 1000 No Gbic Gi3/6 inactive 1 full 1000 No Gbic Gi4/3 notconnect 1 full 1000 1000BaseSX Gi4/4 notconnect 1 full 1000 No Gbic Gi4/5 inactive 1 full 1000 No Gbic
If you need any other commands just let me know...
Any help would be much appreciated!
Thanks in Advance,
Matt
02-01-2017 08:25 PM
It appears that you are using the X2 TwinGig converters that allow you to use the 10 Gbps ports as 2 each 1 Gbps ports.
Here's what they look like: http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-e-series-switches/product_data_sheet0900aecd805bbee3.html
"show inventory" should confirm their presence.
As the interface status shows, there are two 1000BaseSX transceivers installed (one in each supervisor) and only one of them (in slot 3/3, the leftmost port) has an active link.
02-03-2017 02:22 AM
Hey Marvin, thanks for your reply!
Below is the show inventory output from the 4507R...
JWP4507RATL#show inv
NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4507R-E 7 slot switch "
PID: WS-C4507R-E , VID: V01 , SN: XXXXXXXXXX
NAME: "Clock Module", DESCR: "Clock Module"
PID: WS-X4K-CLOCK-E , VID: V01 , SN: XXXXXXXXXX
NAME: "Mux Buffer 1 ", DESCR: "Mux Buffers for Redundancy Logic"
PID: WS-X4590-E , VID: V01 , SN: XXXXXXXXXX
NAME: "Mux Buffer 2 ", DESCR: "Mux Buffers for Redundancy Logic"
NAME: "Mux Buffer 5 ", DESCR: "Mux Buffers for Redundancy Logic"
NAME: "Mux Buffer 6 ", DESCR: "Mux Buffers for Redundancy Logic"
NAME: "Mux Buffer 7 ", DESCR: "Mux Buffers for Redundancy Logic"
NAME: "Linecard(slot 1)", DESCR: "10/100/1000BaseT (RJ45)V with 48 10/100/1000 baseT voice power ports (Cisco/IEEE)"
PID: WS-X4548-GB-RJ45V , VID: V11 , SN: XXXXXXXXXX
NAME: "Linecard(slot 2)", DESCR: "10/100/1000BaseT (RJ45)V with 48 10/100/1000 baseT voice power ports (Cisco/IEEE)"
PID: WS-X45-SUP6L-E , VID: V04 , SN: XXXXXXXXXX
NAME: "Converter 3/1", DESCR: "Converter Module"
PID: CVR-X2-SFP , VID: V02 , SN: XXXXXXXXXX
NAME: "GigabitEthernet3/3", DESCR: "1000BaseSX"
PID: GLC-SX-MM , VID: V04 , SN: XXXXXXXXXX
NAME: "Converter 3/2", DESCR: "Converter Module"
NAME: "Converter 4/1", DESCR: "Converter Module"
NAME: "GigabitEthernet4/3", DESCR: "1000BaseSX"
NAME: "Converter 4/2", DESCR: "Converter Module"
NAME: "Linecard(slot 6)", DESCR: "10/100/1000BaseT (RJ45) with 48 10/100/1000 baseT ports"
PID: WS-X4448-GB-RJ45 , VID: V05 , SN: XXXXXXXXXX
NAME: "Linecard(slot 7)", DESCR: "10/100/1000BaseT (RJ45) with 48 10/100/1000 baseT ports"
PID: WS-X4548-GB-RJ45 , VID: V06 , SN: XXXXXXXXXX
NAME: "FanTray 1", DESCR: "FanTray"
PID: WS-X4597-E , VID: V01 , SN: XXXXXXXXXX
NAME: "Power Supply 1", DESCR: "Power Supply ( AC 2800W )"
PID: PWR-C45-2800ACV , VID: V05 , SN: XXXXXXXXXX
NAME: "Power Supply 2", DESCR: "Power Supply ( AC 2800W )"
And here is a screenshot of the Inventory window from Cisco Network Assistant. Seems as though there are 4 SFP modules, does that sound correct?
Thanks again for your reply, much appreciated!
Thanks,Matt
02-03-2017 02:22 AM
Your "show invenstory" output is from a different 4500 - a 4510R (not a 4507).
The inventory window shows converter modules, two in each supervisor (slots 3 and 4). It does not show any SFPs. (CVR-X2-SFP is the converter only - the actual SFPs are separate parts).
02-03-2017 09:00 AM
Woops, sorry that was for a different location.
I've edited my original response to show the correct 4507R now... Thanks for pointing that out.
Thanks Again,
Matt
02-04-2017 07:01 PM
Yes your edited inventory shows the expected converter modules and SFPs. The output does not distinguish that a single converter module spans two interfaces; but we know that from a priori knowledge about the part's physical characteristics.
