ā02-02-2017 09:18 AM - edited ā03-05-2019 07:58 AM
Hello All,
We are using IOS isr4300-universalk9.03.16.02.S.155-3.S2-ex and i am configuring the below IP sla on the router but its not working
ip sla 31
http raw http://X.X.X.X
http-raw-request
GET http://X.X.X.X/test/HTTP/1.0\r\n
User-Agent: Cisco IP SLA\r\n
\r\n
exit
threshold 300
IPSLA operation id: 31
Latest RTT: 91 milliseconds
Latest operation start time: 17:16:22 UTC Thu Feb 2 2017
Latest operation return code: Http Error <-------------------********
Latest DNS RTT: 0 ms
Latest TCP Connection RTT: 13 ms
Latest HTTP Transaction RTT: 78 ms
Number of successes: 0
Number of failures: 18
Operation time to live: Forever
same above config was working on earlier 2800 series router..
Ranjit
ā02-02-2017 10:12 AM
there might just be a small syntax error. Try to add 'url' as below:
ip sla 31
http raw url http://X.X.X.X
http-raw-request
\r\n
exit
threshold 300
ā02-03-2017 01:16 AM
Hello Georg,
Unfortunatelty the url is not supported in this IOS XE isr4300-universalk9.03.16.02.S.155-3.S2-ex
rtr(config-ip-sla)#http raw ?
WORD URL
rtr#http raw url http://X.X.X.X
% Invalid input detected at '^' marker.
Ranjit
ā02-03-2017 01:35 AM
Hello Ranjit,
I'll check further...
Which URL are you tracking ?
ā03-22-2017 11:26 AM
Hello All,
Pardon me for a late reply, actually after troubleshooting found out the URL/sytax was incorrect.
We are tracking Zscaler URL..
Ranjit
ā02-03-2017 02:39 PM
Since you have used number 31 , try using number 32 now. Just kidding :)
See below format could help you
ip sla 32
http raw http://x.x.x.x source-ip {either loopback or WAN IP}
http-raw-request
GET http://example.com/test HTTP/1.0\r\n
end\r\n
\r\n
\r\n
\r\n
exit
ip sla schedule 32 life forever start-time now
