02-06-2017 07:49 PM - last edited on 03-25-2019 08:56 PM by ciscomoderator
I am running Jabber (11.8.0) on a MAC (10.12.3) and I don't remember when Jabber stopped playing sounds when a chat comes in for example. It is completely quiet. Calls are ok, incoming calls are ringing fine and all my other apps like Outlook are generating sounds for their notifications. Any idea where to start?
Thanks.
Solved! Go to Solution.
06-07-2017 07:29 AM
don't suppose you ever found resolution for this? I also have the problem along with some coworkers, internal tech support hasn't solved it
02-06-2017 08:39 PM
Might want to reach our internal IT for assistance.
02-06-2017 09:24 PM
Thank you, Jaime. Might do that as a last resort.
06-07-2017 07:29 AM
06-26-2017 02:06 PM
I'm also having this issue. Thanks for noting that internal support hasn't solved it. At least that saves me a phone call. Anyone know if a fix is on the way?
06-28-2017 08:17 AM
After a few updates, I got sound again.
06-28-2017 03:49 PM
I hope that happens for me. I'm using the latest—11.8.0 (249632)—and it's still a problem.
06-28-2017 05:10 PM
Mary, I am using 11.9.0 (253531) on Mac OS-X. Just FYI.
06-28-2017 06:26 PM
06-29-2017 05:33 AM
Are you on ACE?
06-30-2017 05:37 PM
I'm not sure, actually. How might I check?
07-07-2017 03:06 AM
Just wanted to add a "me too". I've got a user with an iMac running OS X10.12.5 and Jabber for Mac 11.8.1 and a Sennheiser C60 headset. Setting audio volume and changing ringtones provides audio output, Jabber is set to use all devices for alerts, but incoming calls produce no audible alert.
08-29-2017 12:28 PM
is there any solution for getting sound to work on 10.12.6 and 11.9 jabber? makes it pretty tough to use as a communication tool when you don't know somebody is communicating with you.
09-07-2017 07:06 AM
