UCCX 11.5 Upgrade install Not Aknowledging Completion
Feb 7th, 2017
I am working on upgrading our UCCX HA nodes running System version: 10.6.1.10000-39 to 11.5.1.10000-61. I am practicing the upgrade in a lab environment.
When I run the upgrade, the upgrade appears to be successful, but will still say "running" indefinitely. If I then reboot the machine, the inactive version is 11.5, but I get the message "error.switch.uccx.ovfmismatch"  when I try to switch versions.
I then power off the virtual machine, upgrade the RAM from 8gb to 10gb, and power it back on. After this upgrade I am able to switch the versions VIA the GUI. but not the CLI. I get an error message from the CLI, but the switch version works from the GUI.
My questions:
1. Am I missing a COP file or something? I looked in documentation, but could find nothing.
2. Has anyone seen this problem where the installation appears to succeed but is stuck at the screen that says "running"?
Thanks for any advice you can offer!
Chakshu Piplani Thu, 02/16/2017 - 19:52
You can use command :
file view install system-history.log
On CLI, to check the status of upgrade.
