IPv6 for private and public usage?
Feb 7th, 2017
Hi everyone,
I am confused in IPv6, i was research some RFC but certainly i dont knows if i choose the correct. i need to configure some cisco stuff with IPv6 and i want to know what ipv6 use for private and public.
Unique local for private (https://tools.ietf.org/html/rfc4193)
 | 7 bits |1|  40 bits   |  16 bits  |          64 bits           |
      | Prefix |L| Global ID  | Subnet ID |        Interface ID        |
   Where:
      Prefix            FC00::/7 prefix to identify Local IPv6 unicast
                        addresses.
      L                 Set to 1 if the prefix is locally assigned.
                        Set to 0 may be defined in the future.  See
                        Section 3.2 for additional information.
      Global ID         40-bit global identifier used to create a
                        globally unique prefix.  See Section 3.2 for
      Subnet ID         16-bit Subnet ID is an identifier of a subnet
                        within the site.
      Interface ID      64-bit Interface ID as defined in [ADDARCH].
Global unicast for pyblic (https://tools.ietf.org/html/rfc3587)
 | 3 |     45 bits         |  16 bits  |       64 bits              |
    |001|global routing prefix| subnet ID |       interface ID         |
Site-Local is depreceated (https://tools.ietf.org/html/rfc4291#section-2.5.7)
Overall Rating: 5 (1 ratings)
Seb Rupik Fri, 02/10/2017 - 09:38
  • Silver, 250 points or more
Hi Jorge,
Ask yourself why you are wanting to implement ULA in your IPv6 network. If it is because it bears a striking resemblance to RFC1918 and its functionality, and that is a design paradigm you're familiar with, then you should reconsider. Private addressing was conceived due to address scarcity, something that IPv6 does not suffer from!
If I were you, I'd use GUA throughout your network and at the very least protect it with a perimeter firewall.
cheers,
Seb.
Related Content
