UCCX replication issues
Answered Question
Feb 9th, 2017
We just upgraded a UCCX server from 8.5.1 SU3 to 8.5.1 SU4 and when we did this we got a replication issue.  We pressed the "Reset Replication" button and when it came back only the publisher server shows up in the list. (see attached for before and after screen shots).  The following is what we see in the CLI
Publisher
admin:utils uccx dbreplication status
Error: Replication server status cannot be obtained
Error: connect to SVK606_uccx failed
Enterprise Replication not active  (62)
command failed -- unable to connect to server specified  (5)
Subscriber
Error: connect to KAM1OPAPP87_uccx failed
Correct Answer by Chakshu Piplani about 5 months 1 week ago
Please open a TAC case to get the replication fixed, the engineer might have to go into root to check the files for replication.
Final option might be to re-build node 2 to setup replication again.
Chakshu Piplani
Overall Rating: 5 (1 ratings)
Correct Answer
Chakshu Piplani Sat, 02/11/2017 - 18:17
  • Cisco Employee,
Chakshu Piplani
luhidalg Thu, 02/16/2017 - 17:34
  • Cisco Employee,
Hello ,
We  can try this sequence to reset enterprise replication of UCCX
1.
Stop on node 1--- utils dbreplication stop all (n1)
 Stop on node 2-- utils dbreplication stop  (n2)
 2.
Dropadmindb on node 1.
 utils dbreplication dropadmindb
 Dropadmin db on Node 2.
3.
Reset all (node 1).
 utils dbreplication reset all
Chakshu Piplani Thu, 02/16/2017 - 19:46
  • Cisco Employee,
The steps you have provided are for platform replication.
Issue is with UCCX replication.
