02-12-2017 12:03 AM - edited 03-17-2019 09:30 AM
I need to disable power saver option on DX650 and 8851 sip phones registered to CME 11.6
the screen go off after some minutes of idle time and I need it to be always light
Checking the phone setting didn't help
also configuring it under telephony service didn't help
Please advise how to do that
02-12-2017 10:34 AM
Did you try to use the command
telephony-service
service phone displayIdleTimeout HH:MM
You can use 23:59. Although this is under telephony-service, it will apply to both sccp and sip phones.
02-12-2017 11:09 AM
Thanks for your reply
Yes I use it 23:59 with start time at 00:01
But it didn't work for both sip phones DX650 & 8851
I reset the CME with no help
05-10-2018 06:50 AM
Hi there,
Have you find some solution here?
Is there an equivalent config for the sip phones on cme 12.0?
The following partial output shows a template in which programmable parameters for phone and display functionality have been configured by using the service phone command:
ephone-template 1 button-layout 7931 1 service phone daysDisplayNotActive 1,2,3,4,5,6,7 service phone backlightOnTime 07:30 service phone backlightOnDuration 10:00 service phone backlightidleTimeout 00.01
05-10-2018 06:58 AM
