02-12-2017 02:33 AM - edited 03-08-2019 09:18 AM
HI all,
I have a 8501, and I want to install
Solved! Go to Solution.
02-13-2017 11:20 AM
The steps are:
1) Install CentOS or RHEL on one of your servers
2) Download and install packstack just as it is mentioned in the links I provided
3) Execute a packstack all-in-one installation
4) Install CentOS or RHEL in your other two servers
5) Execute the add-compute-node procedure and include the IP address of the other nodes that you installed in step 4, the procedure is executed from your initial node installed i.e. same place you executed step 3.
What it will do is connect via ssh to the other nodes and download all packages and everything required.
02-12-2017 07:20 PM
I have not done this, but UCS can be integrated with Openstack.
Have a look at this link for more info:
http://www.cisco.com/c/en/us/solutions/data-center-virtualization/openstack-at-cisco/ucs-red-hat-openstack.html
02-12-2017 11:06 PM
But can I use the
02-13-2017 05:13 AM
Yes you can, if you are looking for testing you can install devstack or packstack.
You should think of KVM (there are other options, including leaving your ESXi) as your ESXi in VMware and openstack as the vCenter that helps manage your hosts (from the networking, storage, compute, etc. perspective)
02-13-2017 06:22 AM
Hello Luis,
Thanks for your update, you think it will be good Idea leave the ESXI and then the Openstack?
Is there any doc Cisco has about this ?
thanks.
02-13-2017 07:56 AM
I would not leave ESXi, I would install KVM (packstack will do that for you), but you do need to install the Linux OS. How many servers do you have? Is it just one ? You can do what is called an All-In-One openstack installation, if you have more than one you can use one for control functions and both of them for compute. I am not aware of any Cisco doc on this, but it is just a matter of installing an Operating System (CentOS or RHEL) in each server and then executing the packstack installation, the page has a step by step guide.
02-13-2017 10:10 AM
I will have 3 servers, I will do the install of the OS via the CIMC, in the UCS I have 4 hard drives.
thanks.
02-13-2017 10:38 AM
I would go with packstack. Use one of the servers as control, network and compute node and install compute on the other two.
Like I said it is all done using packstack you can start by installing in a single node and then adding more compute nodes, that way it may be easier.
02-13-2017 11:03 AM
When I do the install via the CIMC, and install the OS in this case redhat i will loose all the info, what I dont understand is how in this server I can install 2 or 3 nodes, because I will only have on OS.
I have 4 hard drivers, I will install via CIMC Redhat, this will delete all the info I have in my hard drives, how can i then install one compute and one controller?
thanks.
02-13-2017 11:20 AM
The steps are:
