Live data Agent & Skill statistics showing Blank
Feb 12th, 2017
We are using Finesse with Live data statistics for  Live data . Agent and Skill Group status reports on Finesse Supervisor desktop layout .
Same finesse we are using second tap for EIM WIM Login page .  I tried using HTTPS with FQDN name .
Finesse version : 11.0.1
IE Version : 11.0.9600
UCCE : 11.0.2
If I disabled compatibility view – I am able to see the Live data reports , but not able to get EIM WIM login window
If I enabled compatibility mode – I am not able to get Live data reports  it was blank , but able to login EIM WIM login window
Please let us know , how we can achieve both the features using IE .
Mozilla can’t support   EIM WIM gadgets  using Live data & EIM WIM
Thanks & Regards,
S. Ram
Anoop Krishnan Sun, 02/12/2017 - 22:37
Appears like a Bug to me, please go through CSCuu18876 , though it's fixed in 11.x .
Also please check if you have given any special characters as the password, i had read that in few threads that finesse gives issues if it has a special character in the password.
The last step would be checking Administrator right's to Supervisors, if so please remove the Administrator rights and have a check.
Anoop
Ramamoorthy Sha... Wed, 02/15/2017 - 00:56
Hi Anoop,
There is no special character in password .and there is no administrator rights for supervisor .
 My doubt is when I enabled Compatibility mode in internet explorer  finesse ,  live data team and Skill group statistics  are blank .
If I removed from compatibility mode finesse ,   live data team and Skill group statistics  are working  fine .
But we need to use the EIM WIM gadget in finesse second window . If I removed compatibility mode , we are not able to get the EIM WIM login window .( its showing only the Table not the login name and image )
Thanks & Regards,
S. Ram
Anoop Krishnan Wed, 02/15/2017 - 23:04
Hi Ram,
Please feel free to try the following on your Internet Explorer
Internet Options -> Security Tab -> Trusted Sites -> Custom Level
Under Miscellaneous
Display Mixed Content - Set to Enable.
Please let me know , if it works
Anoop
Ramamoorthy Sha... Mon, 02/20/2017 - 01:10
Hi Anoop,
I have verified and found the above setting is enabled .Please let us know how to fix it .
Ram.S
