ā02-13-2017 08:22 AM - edited ā03-01-2019 01:04 PM
We have some UCSB-F-FIO-785
I can only see the newer type cards in the B200 M4 pdf but was wondering if anyone tried it (http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-servers/b200m4-specsheet.pdf):
UCSB-F-FIO-1600MS
UCSB-F-FIO-1300MP
Jeroen
ā02-13-2017 08:55 AM
Greetings.
The B200M4 does list those two cards in its spec sheet
Cisco Storage Accelerators
UCSB-F-FIO-1600MS UCS 1600 GB Fusion ioMemory3 SX Scale line for B-Series Mezzanine
UCSB-F-FIO-1300MP UCS 1300 GB Fusion ioMemory3 PX Performance line for B-Series Mezzanine
Kirk...
ā02-13-2017 09:03 AM
Hi Kirk,
Thanks for your reply. I think you have misunderstood my question.
I am asking if the UCSB-F-FIO-785M is compatible with the B200 M4?
Jeroen
ā02-13-2017 07:30 PM
I cannot find any documentation where the UCSB-F-FIO-785M is validated/tested with the B200M4. It may have to do with the UCSB-F-FIO-785M being EOS since 2015 and the newer ioMemory3 line coming out back then.
Best case scenario, is that you get it to discover correctly, but are in an unsupported config.
Kirk...
