02-13-2017 09:02 AM - edited 03-01-2019 08:29 AM
The VPC uplink on Nexus 5672UP Chassis faced the *PVID_Inc issue.
Hardware & Software details:
Nexus 5672UP Chassis : kickstart version 7.1(0)N1(1b) & system version 7.1(0)N1(1b)
Nexus 7010 Chassis : kickstart version 5.2(4) & system version 5.2(4)
Observation on Nexus 5K: STP root for VLAN 1 become one of the N5K and the uplink ports become blocked with error "*PVID_Inc". This message usually comes when the Native VLAN configuration miss-match in configuration on interface level. However in this case, the configuration was very straight forward with default Native VLAN 1. But the error appeared in both N5K and we were not able to access the management IP on Nexus 5K itself.
This TechNotes explains about the possible reason for *PVID_Inc - http://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/24063-pvid-inconsistency-24063.html#topic2
N5K-1# show spanning-tree
VLAN0001
Spanning tree enabled protocol rstp
Root ID Priority 32769
Address 00de.fb07.517c
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Interface Role Sts Cost Prio.Nbr Type
Po11 Desg BKN*1 128.4106 (vPC) P2p *PVID_Inc
Po100 Desg FWD 1 128.4195 (vPC peer-link) Network P2p
N7K-1# show spanning-tree vlan 1
VLAN0001
Root ID Priority 4097
Address 0023.04ee.be01
Cost 1
Port 4195 (port-channel100)
Bridge ID Priority 8193 (priority 8192 sys-id-ext 1)
Po1 Desg FWD 1 128.4096 (vPC) P2p
Po2 Desg FWD 1 128.4097 (vPC) P2p
Po3 Desg FWD 1 128.4098 (vPC) P2p
Po4 Desg FWD 1 128.4099 (vPC) P2p
Po5 Desg FWD 1 128.4100 (vPC) P2p
Po6 Desg FWD 1 128.4101 (vPC) P2p
Po7 Desg FWD 1 128.4102 (vPC) P2p
Po8 Desg FWD 1 128.4103 (vPC) P2p
Po10 Desg FWD 1 128.4105 (vPC) P2p
Po11 Desg FWD 1 128.4106 (vPC) P2p
Po100 Root FWD 1 128.4195 (vPC peer-link) Network P2p
Eth8/17 Desg FWD 2 128.1041 P2p Peer(STP)
Eth8/18 Desg FWD 2 128.1042 P2p Peer(STP)
N5K-1# show int po11 switchport
Switchport: Enabled
Switchport Monitor: Not enabled
Operational Mode: trunk
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Allowed: 1-4094
Voice VLAN: none
Extended Trust State : not trusted [COS = 0]
Administrative private-vlan primary host-association: none
Administrative private-vlan secondary host-association: none
Administrative private-vlan primary mapping: none
Administrative private-vlan secondary mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
N7K-1# sh int port-channel 11 switchport
Switchport: Enabled
FabricPath Topology List Allowed: 0
Finally, we have upgraded the code on N5K to latest recommended code and without even doing any further configuration changes, the *PVID_Inc issue for resolved.
kickstart: version 7.1(4)N1(1)
system: version 7.1(4)N1(1)
Any of you have faced very similar issues? Does this issue resolved in any other way. Appreciate on your inputs.
Balaji Rajan
Solved! Go to Solution.
04-28-2017 07:36 PM
We had the same issue, TAC isolated this to a bug and recommended Upgrade.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCus89196/
Raja
04-28-2017 07:36 PM
Raja
