Warning message
No POE
Feb 13th, 2017
I have a SG300-10MP that is connected to a Ubiquiti Gateway switch on port 1. Even though I have POE enabled the ports do not provide power over ethernet, otherwise they function normally. I have even reset the switch to the default settings without any luck. See image below for settings.
I have a second SG300-10MP connected to the one above on port 2. When I plug in the same POE device to that one it provides power.
Is there anything I have set up incorrectly?
