02-14-2017 03:56 AM - edited 02-21-2020 09:09 PM
Need help anyone.
Encountered this error using installed anyconnect-predeploy-linux-64-3.1.13015-k9.tar.gz on Redhat 6.8 server 64bit.
Attached error screenshot.
Thanks in advance.
02-14-2017 04:38 AM
You have to upload and reference the Anyconnect for Linux .pkg file on the ASA. For example, you ASA should show you this:
webvpn
enable outside
anyconnect image disk0:/<anyconnect-for linux-filename>.pkg
Do a "show run webvpn" on your ASA to check the above.
02-14-2017 04:48 AM
Thanks Rahul for quick revert!
We'll ask our network team to perform the steps provided.
02-23-2017 09:32 PM
Hi Rahul,
May we know the update on this please.
Thank you!
02-19-2017 07:45 PM
Hi Rahul,
Here is the result.
# sh run webvpn
webvpn
enable IBS
anyconnect image disk0:/anyconnect-win-3.1.05160-k9.pkg 1
anyconnect image disk0:/anyconnect-linux-3.1.05160-k9.pkg 2
02-24-2017 03:19 AM
Are you connecting from a 64 bit linux machine? The package file "anyconnect-linux-3.1.05160-k9" is only for 32 bit Linux. There should be another linux package for 64 bit that you have to upload. 3.1 and earlier versions supported 32 bit Linux so there were 2 packages. Now 4.x releases only support 64 bit so there is only one package.
02-24-2017 03:23 AM
Yes, I'm connecting from RHEL 64bit server.
02-24-2017 03:27 AM
You need to upload to the 64 bit package on the ASA:
anyconnect image disk0:/anyconnect-linux-64-3.1.05160-k9.pkg 3
Or you can upload some of the newer Anyconnect 4.x linux package on the ASA.
