02-15-2017 02:31 AM - edited 03-01-2019 03:05 PM
How can i push my tunnel traffic in this case on load balancing traffic on both the ISP's.
02-15-2017 03:04 AM
If you set the cost of one of the links to be much higher than the other it should make it a backup path in opsf so its only used if the primary link failed
ip ospf cost 5000
https://supportforums.cisco.com/document/27461/how-configure-ospf-cost
02-16-2017 01:58 PM
Hi Mark,
Currently i have Dual ISP's and Dual routers.
We had tunnels to our destination on both the ISP's internet links and using OSPF as failure.
Now we want to load balance the traffic on both the ISP's . So how do i push these tunnel traffic in this case.
Can you help me..
