02-15-2017 08:54 AM - edited 03-08-2019 09:21 AM
I'm trying to setup intra vlan netflow to monitor traffic within the same Vlan (IP source/dest, mac source/dest, port source/dest)
On a 3750x running 15.2(4)E2 IPServices
When I try to add the flow to the layer 2 vlan, I get the following error:
% Flow Monitor: 'MONITOR1' could not be added.
My setup:
flow exporter AWSSplunk description AWSSplunk destination 10.34.13.245 transport udp 9996 option interface-table timeout 60 option application-table timeout 60 flow record RECORD1 match datalink mac source-address match ipv4 protocol match ipv4 source address match ipv4 destination address match transport source-port match transport destination-port flow monitor MONITOR1 exporter AWSSplunk cache timeout inactive 30 cache timeout active 60 record RECORD1
Error:
vlan configuration 16 ip flow monitor MONITOR1 input
I was able to do the same config on a 3850 but not on 3750x
Is this not supported on 3750x ?
02-15-2017 09:52 AM
For 3750x, you need the network service module ( C3KX-SM-10G).
Flexible NetFlow is supported only on the Catalyst 3750-X and 3560-X switch running the IP base or IP services feature set and equipped with the network services module. It is not supported on switches running the NPE or the LAN base image.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/configuration/guide/3750xcg/swmnetflow.html
02-15-2017 10:25 AM
We got this module installed:
C3KX-NM-10G
02-15-2017 10:53 AM
So, is a port on the ( C3KX-SM-10G) module configured to export the flow?
02-15-2017 11:00 AM
adding:
to the Port-Channel interface (Te interfaces part of the module) gives the same error message:
05-28-2019 07:40 AM
I am in the same boat using a 3750X switch with IPBase license.
