02-15-2017 06:40 PM - edited 03-17-2019 09:32 AM
I'm a complete newbie with this VOIP stuff.
How can I set up Unity Connection to allow my staff to forward calls directly to a users voicemail?
The way it is setup now we just can forward to an extention and have to wait for it to ring out.
Solved! Go to Solution.
02-16-2017 06:43 AM
This is old but still works
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/26862-transfer-voicemail.html
02-15-2017 06:46 PM
If you go to CUCM and check what the number of the voicemail huntpilot is, you can callforward all a phone directly to Voicemail, using the same voicemail huntpilot number of the forwarding phone.
Please rate if helpful
02-15-2017 06:58 PM
Thanks for the reply.
We don't have a voicemail huntpilot.
I should clarify, we didn't setup this system so I may need to add things.
I have copied a pre-existing HP. How do I configure it? Can you point me to a KB article?
02-16-2017 06:43 AM
02-16-2017 07:46 PM
Thank you. Worked like a charm.
