Cisco Router 2901 - crypto isakmp command unavalible
nabilomar1
Hello everyone,
I'm configuring remote access vpn, and i'm unable to find the isakmp command. What kind of security license do i need to get to solve this problem?
2 Accepted Solutions
Yes, the licensing guide above is for the 2900 series (ISR G2) routers.
SECK9
Offers the security features found in Advanced Security IOS image on ISR 1800,2800 and 3800 e.g. IKE v1 / IPsec / PKI, IPsec/GRE, Easy VPN w/ DVTI, DMVPN, Static VTI, Firewall, Network Foundation Protection,GETVPN etc.
Do this:
conf t
license boot module c2900 technology-package securityk9
Accept EULA
Reboot
You can use the evaluation version for 8 weeks. If license is purchased, it will show up as permanent and can be used forever.
10 Replies 10
Mark Malone
Hi You need a K9 image on it too for crypto  , do you have that running ?
you can check what its currently running in show version
Index 2 Feature: securityk9
        Period left: Life time
        License Type: Permanent
my crypto is running, but i can't find the isakmp.
R2(config)#crypto ?
  key  Long term key operations
  pki  Public Key components
You don't have an enabled security license , it needs to say activated or permanent
here is my show license:
Period left: Not Activated
Period Used: 0  minute  0  second
License Type: EvalRightToUse
License State: Not in Use, EULA not accepted
License Count: Non-Counted
License Priority: None
Do this:
conf t
Accept EULA
Reboot
Thank you very much!
Rahul Govindan
You would need the seck9 license to run ipsec.
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/software-activation-on-integrated-services-routers-isr/white_paper_c11_556985.html#wp9000791
does it work with 2901?
SECK9
