Agent transfer call to another skill group using Cisco Finesse 11.5
Ritesh Desai
Hi folks,
I reviewed the messages on Cisco support forum but most of them are related to CAD and CTIOS. Need suggestion on how shall I achieve "Agent can transfer / re-route to another skill group" Usually this happens when customer call is landed in wrong skill group.
Am using Packaged CCE 11.5.1 solution.
Please suggest.
thanks & regards,
Ritesh Desai.
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
Sasikumar Divvela
Finesse desktop also have transfer button. Agent can use that option to dial to different number.
Are you looking for different option than this ?
Anoop Krishnan
Hi Ritesh,
I guess, you are speaking about the Warm Transfer here, and you would be using CVP as a part of the Solution, please find the thread discussing Network Transfers and how to achieve them, in the below thread, i hope this helps.
https://supportforums.cisco.com/document/29531/network-transfers-cvp#Agent_Transfer_
Anoop
