SNMP newbie question
shahin shahini
Hi Guy's,
We have a Catalyst 3560 Switch that 2 years ago we did setup a SNMP community and an IP address so that only this IP address can read the snmp traps.
now the IP of the machine has been changed and we have to also change the community  and IP address,
can we simply run this commned:
snmp-server community public
snmp-server host 192.180.1.111 version 1 public
Does this change the current configurd SNMP or will create a new group with this new address?
Reza Sharifi
You have to delete the old one first and than add the new one.
If you just add the new one, you will have 2 statements with 2 different IPs and 2 groups.
Hi Reza
Thanks for replay
is this correct
First run this
no snmp-server host 192.180.1.33 public
And then
Is this correct
Yes, that is correct but you probably want to use the new IP in the second statement right?
Yes Reza i will change the ip adres in second statement and leave the community as it is because we that dont Want to chane the name
