Cisco ISE 2.0 Error "Unable to send SMS"
Hi All,
Unable to send SMS notification via Sponsor portal.
SMS gateway is reachable. I am using SMS interface type : HTTP API.
Attached is screenshot.
Any help would be appreciated!!!!
Thanks & Regrads
Laxmi K
6 Replies 6
HI ,
Any suggestion on how we can proceed with troubleshooting on SMS issue. if any one could suggest would gr8!!!
Thanks..Laxmi
Apply a tcpdump on your PSN towards the sms gateway and check the captures. I have a few deployments using Clickatell as an SMS gateway and I can see the API requests in the TCP dump. I have used this to troubleshoot SMS issues in the past.
cammaher
Did you get a resolution to this issue. We have just started to experience it. it was working one day and now it is not working and we are getting the exact error message that you are.
Cam
I haven't yet tested with the  tcpdump, not got the resolution yet.
Laxmi
Hi Laxmi,
Thanks for taking the time to reply.
We have actually fixed the issue after lots of troubleshooting.
The problem was the SMS Providers Digital Certificate was not in the Trusted Certificate Store, so it couldn't trust the https site that we were making the API call too.
The interesting thing is that I installed it a couple of years ago, so no idea why it 'dissapeared'. We did have another Cisco ISE Bug that was when we created a Certificate Signing Request, the option to bind the singed certificate to the CSR was never available in the GUI. The TAC had to remove all of the CSR's from ISE's Oracle database, so I am thinking they may have removed the SMS Providers as well, by accident.
HPT.
Cheers,
Cam
Thanks Cam for your post.
same here it was working and sudden stopped sending SMS notification. Is there any specific certificate which need to be imported. recently i haven't done any activity on the ISE nodes.
Regrads..Laxmi
