02-20-2017 01:56 AM - edited 02-21-2020 09:10 PM
My Inside network: 10.10.30.0/24
My Outside network: 10.10.90.0/24
My VPN POOL: 192.168.0.0/24
I can ping one way ie from 10.10.30.195 to 192.168.0.1 but not from 192.168.0.1 to 10.10.30.195
Here below is my configurations
: Saved
ASA Version 9.1(2)
hostname XXXX
enable password 8Ry2YjIyt7RRXU24 encrypted
names
ip local pool SVCPOOL 192.168.0.1-192.168.0.254 mask 255.255.255.0
interface GigabitEthernet0/0
nameif inside
security-level 100
ip address 10.10.30.1 255.255.255.0
interface GigabitEthernet0/1
nameif outside
security-level 0
ip address 10.10.90.1 255.255.255.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
shutdown
no nameif
no security-level
no ip address
ftp mode passive
object network INSIDE
subnet 10.10.30.0 255.255.255.0
object network OUTSIDE
subnet 10.10.90.0 255.255.255.0
object network PAT_10.10.90.1
object network PAT_OUTSIDE
object network NAT_EXMPT
range 192.168.0.1 192.168.0.254
object network ANYCONNECT_192.168.0.0
subnet 192.168.0.0 255.255.255.0
access-list SVCACL extended permit ip 10.10.30.0 255.255.255.0 any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) source static INSIDE INSIDE destination static NAT_EXMPT NAT_EXMPT
nat (any,outside) dynamic interface
route outside 0.0.0.0 0.0.0.0 10.10.90.99 1
route outside 192.168.0.0 255.255.255.0 10.10.90.99 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 10.10.30.0 255.255.255.0 inside
http 10.10.90.0 255.255.255.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh 10.10.30.0 255.255.255.0 inside
ssh 10.10.90.0 255.255.255.0 outside
ssh timeout 5
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
management-access inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable outside
anyconnect image disk0:/anyconnect-win-2.5.2014-k9.pkg 1
anyconnect image disk0:/anyconnect-linux-2.5.2014-k9.pkg 2
anyconnect image disk0:/anyconnect-macosx-i386-2.5.2014-k9.pkg 3
anyconnect enable
tunnel-group-list enable
group-policy WEBVPNPOLICY internal
group-policy WEBVPNPOLICY attributes
banner value WELCOME TO CLIENTLESS VPN
vpn-tunnel-protocol ssl-clientless
group-policy SVCPOLICY internal
group-policy SVCPOLICY attributes
wins-server none
dns-server none
vpn-tunnel-protocol ssl-client ssl-clientless
split-tunnel-policy tunnelspecified
split-tunnel-network-list value SVCACL
default-domain none
address-pools value SVCPOOL
username admin password eY/fQXw7Ure8Qrz7 encrypted privilege 15
username admin attributes
vpn-group-policy WEBVPNPOLICY
group-lock value WEBVPNGROUP
username cisco password 3USUcOPFUiMCO4Jk encrypted privilege 15
username cisco attributes
vpn-group-policy SVCPOLICY
group-lock value SVCGROUP
tunnel-group WEBVPNGROUP type remote-access
tunnel-group WEBVPNGROUP general-attributes
default-group-policy WEBVPNPOLICY
tunnel-group WEBVPNGROUP webvpn-attributes
group-alias WEBVPNUSERS enable
tunnel-group SVCGROUP type remote-access
tunnel-group SVCGROUP general-attributes
default-group-policy SVCPOLICY
tunnel-group SVCGROUP webvpn-attributes
group-alias SVCUSERS enable
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
service-policy global_policy global
prompt hostname context
call-home reporting anonymous prompt 2
Cryptochecksum:d516f11792080d08006fd5bbf5eec2c6
: end
02-20-2017 02:47 AM
I ckecked the config very briefly, and it seems to be ok.
I advice you to check, if host firewall on 10.10.30.195 (maybe, windows firewall) is blocking ICMP traffic from 192.168.0.0/24.
Also, you may use packet capture feature to check, if ICMP Echos apear on inside interface of ASA, and if ICMP Replies come from 10.10.30.195 back to inside interface.
02-20-2017 02:49 AM
Also, it is not neccessary to add static route to 192.168.0.0/24. You can remove the following statement:
02-20-2017 03:07 AM
02-20-2017 03:39 AM
Have you checked host-firewall on 10.10.30.195?
02-20-2017 03:54 AM
Window firewall is okay and have checked it before but even device inside ie switch i cannot be able to ping them but i can ping from switch.
02-20-2017 03:58 AM
What about packet-capture?
May you perform the following test?
1. Configure capture
capture TEST interface inside match ip host 192.168.0.1 host 10.10.30.195
2. Try to perform ping from 192.168.0.1 to 10.10.30.195
3. Post the output of show capture TEST here.
02-20-2017 04:25 AM
Hi Boris,
Below are packet tracer from cli
SR2FW3# packet-tracer input inside rawip 192.168.0.1 1 10.10.30.195 detailed
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
Forward Flow based lookup yields rule:
in id=0x7fffa223ffa0, priority=13, domain=capture, deny=false
hits=8371, user_data=0x7fff9e3de6a0, cs_id=0x0, l3_type=0x0
src mac=0000.0000.0000, mask=0000.0000.0000
dst mac=0000.0000.0000, mask=0000.0000.0000
input_ifc=inside, output_ifc=any
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in id=0x7fff9fc71f20, priority=1, domain=permit, deny=false
hits=260407, user_data=0x0, cs_id=0x0, l3_type=0x8
dst mac=0000.0000.0000, mask=0100.0000.0000
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 10.10.30.0 255.255.255.0 inside
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in id=0x7fff9ebb9940, priority=111, domain=permit, deny=true
hits=864, user_data=0x0, cs_id=0x0, flags=0x4000, protocol=0
src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0
dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0, dscp=0x0
input_ifc=inside, output_ifc=inside
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
02-20-2017 04:28 AM
It is ok. Packet tracer won't show you the correct results in case of VPN, because there is no way to explain for packet tracer, that the test-packet comes from VPN (not just from outside interface).
What about packet capture?
02-20-2017 04:38 AM
Hi Boris,
see the capture below
SR2FW3# capture TEST interface inside match ip host 192.168.0.1 host 10.10.30.$
SR2FW3#
SR2FW3#
SR2FW3# show capture TEST
1206 packets captured
1: 05:07:59.793751 10.10.30.195 > 192.168.0.1: icmp: echo request
2: 05:07:59.798802 192.168.0.1 > 10.10.30.195: icmp: echo reply
3: 05:08:00.595855 192.168.0.1 > 10.10.30.195: icmp: echo request
4: 05:08:00.792210 10.10.30.195 > 192.168.0.1: icmp: echo request
5: 05:08:00.795689 192.168.0.1 > 10.10.30.195: icmp: echo reply
6: 05:08:01.790593 10.10.30.195 > 192.168.0.1: icmp: echo request
7: 05:08:01.794712 192.168.0.1 > 10.10.30.195: icmp: echo reply
8: 05:08:02.789006 10.10.30.195 > 192.168.0.1: icmp: echo request
9: 05:08:02.792332 192.168.0.1 > 10.10.30.195: icmp: echo reply
10: 05:08:03.787419 10.10.30.195 > 192.168.0.1: icmp: echo request
11: 05:08:03.790776 192.168.0.1 > 10.10.30.195: icmp: echo reply
12: 05:08:04.785863 10.10.30.195 > 192.168.0.1: icmp: echo request
13: 05:08:04.789189 192.168.0.1 > 10.10.30.195: icmp: echo reply
14: 05:08:05.595153 192.168.0.1 > 10.10.30.195: icmp: echo request
15: 05:08:05.784215 10.10.30.195 > 192.168.0.1: icmp: echo request
16: 05:08:05.787328 192.168.0.1 > 10.10.30.195: icmp: echo reply
17: 05:08:06.782643 10.10.30.195 > 192.168.0.1: icmp: echo request
18: 05:08:06.786000 192.168.0.1 > 10.10.30.195: icmp: echo reply
19: 05:08:07.781041 10.10.30.195 > 192.168.0.1: icmp: echo request
20: 05:08:07.784337 192.168.0.1 > 10.10.30.195: icmp: echo reply
21: 05:08:08.779515 10.10.30.195 > 192.168.0.1: icmp: echo request
02-20-2017 04:47 AM
So, I see, that there are only echo requests from 10.10.30.195, aren't they?
There are no echo replies from 10.10.30.195. Right?
So, I still believe, that ASA's config is ok. Echo replies from 10.10.30.195 are simply not reaching ASA's inside interface. The problem is somewhere between 10.10.30.195 and ASA.
You wrote previously: "Window firewall is okay and have checked it before". What do you mean by "windows firewall is ok"? Can you try to switch it completely off on 10.10.30.195 host and perform the test one more time?
02-20-2017 05:14 AM
Hi Boris,
I rebooted 10.10.30.195 but result still the same,
02-20-2017 05:35 AM
Ok, but you didn't answer about windows firewall on 10.10.30.195... Can you try to switch it off?
Or, maybe, you don't have specific permitions to modify firewall rules?
02-20-2017 05:35 AM
Hi Boris,
unfortunately, i dont have permission but even using a switch as a host inside the network with ip 10.10.30.9, i cannot be able to ping the switch so firewall is not an issue
02-20-2017 05:38 AM
Ok, but I still advice you to consult with some Microsoft-guys about windows firewall.
What about switch. Does it have the route to 192.168.0.0/24? Or, maybe, does it have any default-gateway configured?
