02-20-2017 05:10 AM - edited 03-08-2019 09:24 AM
This is the config of a router I have inherited and am scratching to understand as quickly as possible.
Yes I have no experience with routers......... A machine connected with a crossover into nterface FastEthernet0/1 gets a 192 address from the pool.
interface FastEthernet0/0 I do not understand.
Are you are to help me out here?
R1#show config
Using 1347 out of 29688 bytes
version 12.4
service timestamps debug uptime
service timestamps log uptime
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1 192.168.0.10
ip dhcp pool THEIPPOOL
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 172.16.10.1 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 172.16.20.1 255.255.255.0
ip helper-address 172.16.10.10
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 172.16.30.1 255.255.255.0
interface Serial0/0
no ip address
shutdown
no fair-queue
interface FastEthernet0/1
ip address 192.168.0.1 255.255.255.0
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
interface Serial0/2
no ip address
shutdown
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input none
end
R1#
02-27-2017 04:52 AM
The physical FastEthernet 0/0 has been configured provide layer 3 interfaces on an 802.1Q trunk connection for the VLANs 10, 20 and 30.
This is probably connected to a trunk port on a layer 2 switch with those 3 vlans configured and will allow routing between the VLANs.
02-27-2017 06:21 AM
As cmcclinton has already noted, FastEthernet 0/0 appears to be configured to work with .1Q VLAN tagged frames. On a Cisco switch, such a port would be usually configured with access-mode trunk. On a Cisco router, such a port is configured using subinterfaces, with the interface name's .# suffix indicating the subinterface identification. BTW, the subinterface identification number doesn't need to match the VLAN tag, but it's good practice to do so.
Also BTW, the main interface could also have an IP address. If it did, it would deal with untagged frames, the "native" VLAN, for a Cisco switch port.
